Re: Update, SA Carb
Posted by old on August 26, 2010 at 12:16:03 from (4.245.7.92):
In Reply to: Update, SA Carb posted by TWheat on August 26, 2010 at 11:24:48:
Do you have an I-T manual or some other such manual?? Do you have the instructions for rebuilding the carb??? Either one or both tell how to set the float and that is something that has to be set as per the manual. Things like timing, point gap, distributor advance all can play into a problem like you have. Shoot even a weak spark can cause that problem you need a good blue/white spark the will jump a 1/4 inch gap
