Try replacing the coil. YT (This site) has them. I put a new coil and condensor in a F-20 mag (Model F-4) and got a 3/8 inch spark.
I used a method described here several years ago. Find a 3/8 inch drive socket that fits the nut on the "Front" end of the armiture. Cut a 3/8 inch drive socket extension in half. Put the male end in a drill and use that and the socket to turn the armiture. Hold one of your spark plug wires near the base as you spin it. Move the spark plug wire away from the base as you spin it and see how wide a gap it will jump. As I said above, I got mine to jump 3/8 of an inch.
One thing extra that I did was to drill a small hole in the inside of the mag cover, connected a wire to the condensor, threaded this wire through the small hole and connected it to a one-wire "Kill" switch from a H or M. This makes it much easier to kill the engine, especially if the original grounding mechanism does not function.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
