Re: IH 3400a Hydro Payloader
Posted by pete 23 on August 26, 2010 at 19:15:37 from (173.87.8.216):
In Reply to: IH 3400a Hydro Payloader posted by Jimjc038 on August 26, 2010 at 12:11:39:
I am not familiar with that model and really never worked on the foot operated hydrostatic drive machines. However, if it does have a dump valve pedal etc for starting like the 656 with pedal hydros, that is the first thing I would suspect. If you unhook the return line from dump valve no oil should come out of valve, (ALSO VALVE HAS TO SEAT COMPLETELY WITH NO INTERFERENCE FROM DIRT OR STRIKING PLATFORM ETC). If that is ok, I would remove both lines that go to the reverse alternating check valve block and plug the fittings to eleminate any outside problems from internal problems. I'm not even sure your tractor has these valves so good luck.
