Farmall 560 D hydraulic issues
Posted by scenic acres on August 26, 2010 at 20:01:46 from (70.41.0.39):
Replace hydraulic pump in tractor. Have a lot of air in the system and hydraulic system is jerky. Power steering is the same. Seems like it get a little shot of fluid now and them. Replaced filter, and spring in valve block. Screen is clean. Comntrol valves worked great prior to this issue also. The tractor had no lift capacity even when I increased the rpm"s
