Re: Slow turn over on Super C
Posted by John T on August 27, 2010 at 05:40:55 from (66.244.97.31):
In Reply to: Slow turn over on Super C posted by Brent P on August 26, 2010 at 20:50:22:
First no cost n easy thing Id try is to remove, clean n wire brush, then reattach each n every battery n starter n switch/solenoid n ground cable connection see if that helps
Next be sure the battery is well charged n have it load tested
For 6 volt systems I recommend at least 0 better yet 00 gauge battery n starter n ground cables and the highest CCA rated battery that will fit in the box.
Of course, the starter itslef can be at fault like worn bushings or brushes etc if its NOT a cable or connection or battery problem
If alls well it should crank fine n start even at cold temps so start with cables then look at battery then perhaps the startrr itslef is the problem
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
