Re: Re: Farmall M hydraulic problem
Posted by River Dale Farms on June 13, 2000 at 06:27:36 from (4.19.120.232):
In Reply to: Re: Farmall M hydraulic problem posted by Tirrell on June 12, 2000 at 21:10:53:
Check your hyd pressure when tractor is cold,{morning}, then again when lifting ability is noticably reduced. Probably will show significant difference. These gear pumps are very basic but "rebuilt" does not always mean what we think it should. Take the pump apart and look for scoring between the curves of the housing and pump gear, if visible signs of scoring, pump is not going to be very efficient. There some rebuilders not quite getting the job done right. Thanks, Dale.
Post A Followup
: Re: Re: Re: Farmall M hydraulic problem
