Re: High oil pressure D282
Posted by TractormanNC on August 27, 2010 at 12:26:34 from (209.42.180.81):
In Reply to: High oil pressure D282 posted by BeekeeperArt123456 on August 27, 2010 at 11:30:20:
All the D282s I have been around will hold about 35-40 PSI hot, cold, idling, or wide open throttle.
I have seen worn out ones hold 35 at hot idle.
The original gauge on the 560s was a 0-45 psi gauge. Hasn't been available from CIH for many years as far as I know. The replacement is a 0-75 psi gauge.
Sounds like a good tight 282. If in doubt, replace the gauge with a higher reading one. If not over 50 psi, I wouldn't worry.
