Re: Smoke coming from starter
Posted by Janicholson on August 28, 2010 at 13:34:01 from (67.72.98.45):
In Reply to: Re: Smoke coming from starter posted by walter wallace on August 28, 2010 at 07:38:20:
Not the starter, a failing clutch can be tested by putting it in high gear, full throttle aiming for clear road ahead, and letting out the clutch like you were going to spin the tires. If the engine bogs down immediately and stalls, the clutch is good. if it continues to run fast, and the tractor moseys forward it is toast. If you are a new clutch user with no instruction, (with respect) you may be abusing it. Clutches are to make rapid transitions between stopped and pulling hard one second of slipping is all that is allowed. It is never a speed adjustment. When working to attach an implement, or move carefully, a light slipping is OK for 10 to 15 seconds only. Treat them like a switch. Good luck. Jim
