Re: Oil from exhaust pipe
Posted by bkpigs on August 28, 2010 at 19:45:01 from (75.132.223.199):
In Reply to: Oil from exhaust pipe posted by bkpigs on August 28, 2010 at 18:10:13:
Ring failure was my first notion. But then I got to thinkin' if it was the rings, they would let the compression and combustion gases through to the crankcase. Therefore, with the gases going down there would be little opportunity for the oil to go up. Right?
