Re: IHC Cub LoBoy - Water Temp Gauge
Posted by Mike K on June 13, 2000 at 10:48:56 from (206.159.164.17):
In Reply to: IHC Cub LoBoy - Water Temp Gauge posted by Jerry M. on June 13, 2000 at 10:11:48:
Jerry,Take a look at your upper water outet casting you will see a raised flat spot near the end of the hose,you can drill & tap to your NPT size.If for some reason you can`t find it you can also braze 1/2 of a pipe nipple just above the base on the right side.
Don`t be alarmed at the temps you`ll see.Under load mine run 230-240F.
Some day Im going to find a w/pump to use and see if I can`t convert to a more conventional system.If anybody knows of one I would be interested in hearing about it.....Mike
Post A Followup
: Re: Re: IHC Cub LoBoy - Water Temp Gauge
