Posted by Janicholson on August 29, 2010 at 07:23:25 from (67.72.98.45):
In Reply to: parking tractor safely posted by mike paulson on August 29, 2010 at 07:14:52:
Sideways on a hill is always superior because it will not roll that direction. Use the brake lock (with working brakes it is not a problem. If children are around, I would put a bolt through the flipper hole of a diameter that would keep the flipper from being depressed (kids try all levers and pedals). Low gear (1st) is almost impossible to drag the tractor to turn the engine over. It will slide the tires. So 1st is the answer. I would block the wheels against a RR tie if I thought there was a remote chance of children being around the tractor at all. I would also use a battery disconnect switch in the battery cable to prevent the starter from being used to make it go. I hope this helps. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
