Posted by Jim Becker on August 29, 2010 at 10:34:06 from (173.57.154.186):
In Reply to: wiring famall cub posted by ejensen on August 28, 2010 at 21:23:38:
First off, in case ejensen doesn't have his wiring question completely answered, here is the applicable diagram from the ATIS Cub FAQ.
Now, on to the question about what the "L" terminal contributes to the whole system. Rvirgil came up with the right diagram. I am inserting an equivalent diagram from GSS-1310 (stored on Rudi's Cub manual server).
The current produced by the generator goes into the regulator at the GEN terminal, through a coil in the cut-out relay, through the cut-out contacts, then through the current regulating coil of the regulator relay and finally out the BAT terminal. The L terminal is tapped into this circuit BETWEEN the cut-out contacts and the current coil on the regulator relay. Thus, when the generator is charging, the load (lights, ignition) are fed through from the generator and through the cut-out contacts then directly to the L terminal and that load will not be included in the current limit of the regulator. That way the current limit is only limiting the current actually going to the battery.
Then the generator is NOT charging, battery power feeds into the BAT terminal of the regulator, passes through the current coil of the regulator relay and on to the L terminal to power the lights and ignition. The cut-out contacts will be open preventing a feed into the generator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
