Re: Re: Farmall 300 clutch out?
Posted by Hoosier on June 13, 2000 at 11:11:04 from (208.143.4.230):
In Reply to: Re: Farmall 300 clutch out? posted by cranker on June 12, 2000 at 04:48:20:
Just saw your msg, don't log on that often. There is a grease fitting for the release bearing, you take off the access cover that has the two 9/16" bolts on the underside of the clutch housing. My M did a similar thing a few years ago, the carrier (don't know what else to call it) for the throw out bearing was worn, causing the bearing to seize. Made a heck of a racket & a lot of smoke. Good luck on your project!
Post A Followup
: Re: Re: Re: Farmall 300 clutch out?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
