Re: Farmall 450 clutch
Posted by Brownie 450 on August 29, 2010 at 13:39:10 from (66.43.241.101):
In Reply to: Farmall 450 clutch posted by danto on August 29, 2010 at 09:21:05:
Throwout bearing can cause trouble as well as the pilot bearing getting bad. Wear on pressure plate fingers can cause trouble as well as dryness where the throwout bearing slides. Take the inspection plate off the bottom cover & see if there is a grease fitting on the throwout bearing. If one is there, give it a couple of shots of grease. Dryness on the clutch disc splines is another possible source of trouble.
