Re: What is this??
Posted by Janicholson on August 29, 2010 at 16:55:19 from (67.72.98.45):
In Reply to: Re: What is this?? posted by AL Farmall Boy on August 29, 2010 at 16:34:42:
It is a poor representation of a starting relay (often incorrectly called a solenoid) it is the place to attach the source for the circuit you are considering. Attachment point is under the large battery cable terminal. Not the big terminal that leads to the starter. It is a magnetically operated momentary contact high amperage switch. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
