Re: 3point hitch troubles
Posted by pete 23 on August 29, 2010 at 19:11:58 from (173.87.8.216):
In Reply to: 3point hitch troubles posted by DaveIN on August 29, 2010 at 17:59:40:
Ser number 44854 and above have an easy friction adjustment on each lever, just tighten 5/16 bolt with l/2 head , older ones are more difficult as spring loaded disc on position control lever although draft control lever is easy unless rusted like they usually are. On that you loosen the lock nut on end of shaft and tighten nut if I am remembering correctly. I would say that is the problem.
