Re: Farmall F14 Overdrive Unit
Posted by Fawteen on August 30, 2010 at 03:53:26 from (72.95.102.242):
In Reply to: Re: Farmall F14 Overdrive Unit posted by 36F30 on August 29, 2010 at 15:34:24:
36F30 is correct in that the road gear will not
directly interchange between an F12 and an
F14,BUT...
If you change the transmission input shaft at the
same time you install the road gear, it works just
fine. I have an F12 input shaft and road gear on
my F14. Somewhat of a pain to do, but not
horrible.
An added benefit is a bit more speed, as the F14
changed the gear ratio to maintain the same speeds
with the higher engine RPM.
