Re: F-340 Brakes
Posted by rustyfarmall on August 30, 2010 at 08:03:40 from (209.152.78.140):
In Reply to: F-340 Brakes posted by Leo Davinci on August 30, 2010 at 06:38:01:
It sounds as though you are trying to "out think" the IH engineers that designed and built the brake system which is very rarely a good idea.
I would suggest that when you install the next set of new brake discs, raise one rear wheel off the ground and then rotate that wheel by hand and listen, as as feel, for brake drag. There should be absolutely NO drag on tractor brakes UNTIL pressure is applied to the brake pedal. Tractor brakes are not like the brakes on your car or truck where you WANT a slight amount of drag at all times.
