Look at the detent cam on the back side of the main shift cam on the lever in the lid. See if the spring is missing or if the nubs are worn off from use. If that is good then look at the amount of wear on the sliding gear and on the matching gear After all these years it is probably worn quite a bit. Also if you are having trouble with reverse look at the little flipper on the lid for wear in the lid or on the shaft also the pin and slot on the flipper. There are 3or 4 small rollers on the pins to the whole mechanism don"t lose them or you will find them in the filter later or between gear teeth.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
