Posted by Janicholson on August 30, 2010 at 18:46:21 from (67.72.98.45):
In Reply to: h mipulse rotor posted by PeteEllis on August 30, 2010 at 11:48:12:
I have a little more time now, so here goes. The impulse coupling is designed to trip at TDC. This process initiates earlier in the rotation with a pawl that catches and holds back a spring. The spring winds up for a given number of degrees of rotation. When it trips, the rotor is not pointing to the spark plug terminal. it is leading the terminal slightly. The tripped magnetic rotor spins up to speed making current flow in the primary mag winding. When the current is flowing at max, the points open. This occurs a little after TDC, making sure that there is no chance for kickback if the engine was hand cranked. This breaks the current, and a secondary voltage is generated in the spark windings. This voltage is directed by the rotor to the appropriate spark plug terminal (it is now lined up directly toward that terminal.) When the engine starts, the mag impulse coupling is removed from action by a governor (speed sensor) that pulls in the pawl, preventing spring windup. This also causes the spark to no longer have the delay caused by the impulse system. Thus the spark timing is at full running advance. IH mags of this type have no centrifugal advance. I hope this explains a lot. The timing of the rotor is best set by timing marks on the little gears. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
