Re: Need Help quick on a 140 Motor/Water Pump Running - V...
Posted by AL Farmall Boy on August 30, 2010 at 19:47:28 from (74.248.177.110):
In Reply to: Need Help quick on a 140 Motor/Water Pump Running - Videos posted by AL Farmall Boy on August 30, 2010 at 12:05:37:
***UPDATE***
Engine/Water Pump Noise has been identified and fixed. Apparently one of the bolts on the pump wasn't tightened all the way, but the rest were. THat was causing the funny sqeaking/rattling noise, as well as a small leak. We tightened all the bolts, and fixed the problem.
The only issues we're having now at the moment is the starting switch not working as described above. It is as if the key switch wasn't even hooked up. We are having to jump the starter directly to the battery to start it right now. I will check the terminal on the relay tomorrow as you were telling me to do. I have bought 2 brand new terminals and neither have worked so far. It has to be something else because there is no way that both of them (came from 2 different places) are bad
