Re: What is this??
Posted by Jg20601 on August 30, 2010 at 21:29:06 from (63.28.56.32):
In Reply to: What is this?? posted by AL Farmall Boy on August 29, 2010 at 16:06:51:
From what manual did the pic come from? I have a 140 with electrical problems and have never found a diagram for my tractor - late model 140 ser #63048
From looking at mine this is what I see
1 is headlamp 2 is connector to light assembly
3 is tan wire to coil
4 is my governor has two brackets that are part of the harness, and another larger one (5) that attaches to the thermostat housing... 8 is a bracket that on the left side of the engine also has ground wires atached
19 is the resistor
24 is the starter relay 12 is the cable from the relay to starter 26 is the clutch switch
29 is the taillamp 33 is the hazard/turnsigal lamp
