Brakes Fixed
Posted by farmall706 on August 30, 2010 at 21:53:29 from (71.244.247.38):
Thanks to Pete 23. My Brakes are fixed. I disconnected the brake pedals from the brake valve and the tractor rolls freely, the right brake is not dragging. I adjusted per your direction of the pin slip fitting and the brakes work fine.
Thanks
