Posted by Tom Fleming on August 31, 2010 at 03:37:57 from (206.193.253.243):
In Reply to: h mipulse rotor posted by PeteEllis on August 30, 2010 at 11:48:12:
If I remember correctly, if your mag is timed right, when you install it, the manual says to rotate it slightly to "trip" the impulse when you have the engine on TDC.
In other words, if the timing is correct on the crank, govenor and cam gears, set your #1 cylnder to TDP on compression. Install mag without tightening the bolts. The rotor should be pointed at #1 on the cap. rotate the installed mag to "trip" the impulse. You mag is now timed.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
