Re: Start up after a year and a half....
Posted by El Toro on August 31, 2010 at 04:55:49 from (74.103.74.58):
In Reply to: Re: Start up after a year and a half.... posted by Chris In Pennsylvania on August 31, 2010 at 04:13:39:
Look inside the tank with a good flashlight to see if there's rust in the bottom of the gas tank. If you see a lot of rust the tank may have rusted through and is leaking. Remove the sediment bowl and shutoff valve after you've drained the tank. Once the tank is drained install a pipe plug in the gas tank use teflon tape on the plug then pour some gas back into the tank to see if the tank still leaks. You probably need fresh gas too. Hal
