Re: 1948 Famall Cub with a 3 teminal regulator
Posted by gene bender on August 31, 2010 at 05:36:59 from (67.55.227.196):
In Reply to: 1948 Famall Cub with a 3 teminal regulator posted by ejensen on August 31, 2010 at 05:03:14:
You have a cutout on your generater. Get the gen checked out. Then polarize the gen when installing and you probably will be good to go. Those cutouts were gereraly trouble free. Your service person should be able to check it out also. If you need to replace it make sure you get the correct regulator by using the Delco Remy # on the gen as your gen if original has the thired brush adjustable.
