Posted by farmall57 on August 31, 2010 at 07:20:32 from (12.183.86.164):
In Reply to: 350 Utility Hydo pump posted by tim stephenson on August 28, 2010 at 05:39:19:
For sure you will want to check that screen under the seat. I just went thru this with mine, hitch got where it would hardly move and power steering was barely working. That screen was completely covered with a slimy semi fluid coating and the screen was sucked in on itself like wadded paper. I was able to clean it up and gently push it all back into shape. Works now as it should. Worst thing is getting that cover off, it is very heavy and awkward to handle, I left the hydraulic valves attached and just lifted it enough to get at the screen, reused the original gasket with a dab of silicone in the bad spots....Good luck.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
