Re: Steeped head pistons
Posted by ljs01 on August 31, 2010 at 08:52:03 from (67.224.18.99):
In Reply to: Re: Steeped head pistons posted by Janicholson on August 30, 2010 at 06:35:25:
What would you do if you found the clearances to be too small? Could you use two head gaskets, or would you try to grind off the piston to fit? Just curious.
Thanks
