Re: Gunk in the gas tank
Posted by Bob M on June 13, 2000 at 14:37:23 from (172.160.117.177):
In Reply to: Gunk in the gas tank posted by Jeff on June 13, 2000 at 13:59:23:
The Red's advice is the best way to go. But if you're on a tight budget this can work: Remove the tank from the tractor and remove and throw away the sediment bowl assembly (the bowl's pot metal body is probably rotten now anyway....). Dump out whatever liquid you can from the tank and plug the sediment bowl opening (use a 3/8" pipe plug). Now take a plastic bucket (NOT a metal one), put a couple gallons of cold water in it, then add a can of crystal Draino. Stir it up good, then pour the solution into the tank. (BE CAREFUL! Wear old clothes, use rubber gloves and wear eye protection - this stuff is NASTY!!) Let the tank sit a couple hours, periodically rocking it to agitate the solution. When you think the solution has stopped working, carefully pour it out and dispose of it. Rinse the tank several times with hot water (the hotter the better) then check inside. With luck most of the gunk will have been dissolved and flushed out. However, depending on how much gunk there was in the tank, you may have to repeat the Draino treatment to get it all out. Finish up by tossing a few handfulls of pea gravel or a short length of chain into the tank. Then rock it around a while - the gravel/chain will break off loose rust and crusty stuff from the tank walls. Finally remove the gravel (easier said than done!) or chain, rinse the tank again several times with clean water, then let it dry in for a day or two. Good luck!
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
