Re: super A hydraulic pump
Posted by Andrew Z on August 31, 2010 at 10:01:03 from (64.252.114.101):
In Reply to: Re: super A hydraulic pump posted by Paul Shuler on August 31, 2010 at 09:54:00:
There is not much in those pumps, a washer a large O ring, and some gaskets. I would take apart the pump first and see how badly scorn the body is where the gears ride. If there really bad then look for a new pump
Andrew
