Re: Need Help quick on a 140 Motor/Water Pump Running - V...
Posted by AL Farmall Boy on August 31, 2010 at 10:44:28 from (74.240.94.171):
In Reply to: Re: Need Help quick on a 140 Motor/Water Pump Running - V... posted by DavidA on August 31, 2010 at 10:17:00:
David,
Thanks for your suggestions. I check the ground on the switch this morning, and thats what it was. Yes I am in Alabama, and I've not had good luck with the dealerships on parts. I can usually find the same parts at almost half the price and sometimes more than that.
Right now I need to get a good alternator with the harness plug that plugs into it. My 140 has the 12 volt alternator original from the factory, so it will need to be like those to mount correctly.
