Re: IH 706 for snowblower?
Posted by Dan Swanson on August 31, 2010 at 11:34:38 from (63.172.252.159):
In Reply to: IH 706 for snowblower? posted by Lingcod on August 31, 2010 at 07:53:36:
I've been using a 966 with a hydro to run on a 7' single stage blower for 25 years or so. Use it to load trucks from a windrow of snow that is 7' wide at the base and as high as we can pile it. Like Allen in NE said it will work the heck out of it at times. The hydro really shines in this type of set up. So to compramise you could problably get by with a 706 sized tractor as long as it was a hydro. I know hydros may not be the best for heavy field work, but for blowing snow it works great. We did use a 656 hydro when our 966 was in the shop. The 656 did the job but it took quite a bit longer because the HP wasn't there. Dan
