Re: oil pressure on 1949 M farmall
Posted by Theman on August 31, 2010 at 13:26:26 from (65.198.133.254):
In Reply to: oil pressure on 1949 M farmall posted by james1794 on August 31, 2010 at 12:36:16:
The filter is downstream of the oil pump and only sees a portion of the oil as it flows through the engine (bypass system). The pump is submerged under the oil level in the pan making it difficult to lose prime. Unless you're hearing knocking before the gage is reading low, I bet you have pressure way before it registers on your gage. Could be air in the line, could be a gage problem, or it could be a weak pump. Take the oil line loose from the back of the gage and crank the engine. If oil comes out, you need to replace the gage or live with it being slow. I'd advise replacement with a known good gage before tearing into the engine.
