Re: Whats going on with the governor??? (Video Attached)
Posted by hughb on August 31, 2010 at 14:54:39 from (12.232.190.245):
In Reply to: Re: Whats going on with the governor??? (Video Attached) posted by AL Farmall Boy on August 31, 2010 at 12:14:48:
Took me a little bit to find the video. If it was mine first thing I
would do is unhook the linkage at the carb and see if you get the
same results by advancing the throttle at the carb. In other words
eliminate the carb first as the problem. I just can't picture how the
governor is the problem. It would seem to me that the governor
would only cause a problem at higher rpm.
