Re: 444, burned points
Posted by John T on August 31, 2010 at 17:41:17 from (66.244.97.31):
In Reply to: 444, burned points posted by TJAllen on August 31, 2010 at 17:25:02:
One thing Id suspect is a weak or leaky condensor or its just bad, that can contribute to premature points burn up plus a weaker spark. Also insure it has a good ground and its wire to points and that lil connection to points is good. Of course, excess coil current burns them up faster such as 6 volt unballasted coil use on a 12 volt tractor.
John T
