Re: Whats going on with the governor??? (Video Attached)
Posted by Farmallc on August 31, 2010 at 17:44:55 from (71.49.94.108):
In Reply to: Whats going on with the governor??? (Video Attached) posted by AL Farmall Boy on August 31, 2010 at 12:10:20:
I had this problem with my Farmall C and it was the
spring in the governor that connects to the linkage.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
