Posted by Janicholson on August 31, 2010 at 18:03:53 from (67.72.98.58):
In Reply to: Oil in tach cable posted by Bernie Steffen on August 31, 2010 at 14:34:10:
No issue; The pump seal will make it operate correctly. At least the cable is not starving for lube! I like to clean things up and lube the cable with Lubriplate engine rebuilding grease applies to the cable as it is put in the external cable housing. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
