Re: Need Help quick on a 140 Motor/Water Pump Running - V...
Posted by Janicholson on August 31, 2010 at 18:14:39 from (67.72.98.58):
In Reply to: Need Help quick on a 140 Motor/Water Pump Running - Videos posted by AL Farmall Boy on August 30, 2010 at 12:05:37:
A three terminal just eliminates the I terminal. (Ignore it) The big one close to the S terminal is to be connected to the battery cable, the other big one is the starter connection. Jump from the battery terminal on the relay to the S terminal. (a screw driver will do nicely for this). If it spins the starter, the relay is fine. The S terminal must have voltage from the key to run the starter. Jim
