Re: farmall 560
Posted by hayshaker on August 31, 2010 at 19:28:20 from (208.126.118.49):
In Reply to: farmall 560 posted by jgu on August 31, 2010 at 18:55:06:
What is the diameter of the cylinder? Try a larger diameter cylinder either one or two way will work much better if you don't have any other issues. You will have to change from one way to two way from the correct valve under the dash.
