I took the generator off the tractor and put it in a vice. Hooked up the voltage regulator and installed an amp meter between the battern terminal on the regulator and the 6 volt battery. Grounded the 6 volt battery to the generator. I use a ryobi hammer drill with a cut off 3/8 extension and a 3/4 socket. Took the top off the regulator and the contacts on the coil inside the regulator were open. When I connected the battery teminal to the terminal on the regulator no sparks this time. I closed the points and the generator rotated counter clockwise which is opposite to what it should turn. Had the positive terminal on the battery connected to a ground screw on the generator. Generator would not charge while rotating with the ryobi hammer drill. I grounded the field and still no charge but the points on the regulator closed and there was a noticeable increase in esistance while turning the generator with the drill. I am taking the generator and voltage regulator to Acme electric in Seattle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
