Farmall Tractors Discussion Board
Hydraulics won't work right
Posted by Pat on January 01, 1999 at 19:18:57:
I have a 1961 560 I have owned for several years.
When I purchased it I could lift 2000 lbs in my pig lift. I could lift the rear wheels off the ground. It slowly has gotten weaker and weaker. I replaced the pump this summer and it is a little better but not great. Not good enough to risk purchasing a good hydraulic loader. I have flushed the system, kept water out as best I can (store the tractor inside)etc. I have had suggestions as to look at the Tele-depth, pressure relief valve etc.
Any other suggestions ?????
Post a Followup
: Re: Hydraulics won't work right
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
