Posted by ScottyHOMEy on August 31, 2010 at 20:03:15 from (71.241.194.27):
In Reply to: SC - seat shock posted by 62champ on August 31, 2010 at 19:41:11:
Not sure if I'm thinking of the same part, but if it's that rubber bushing with a bolt coming in from each side of the seat mount . . .
I was ugly enough by the time I got it out that I never took it apart to see what it was made of -- whether a single piece in the middle threaded to take the bolt from each end, or two separate threaded parts embedded in the rubber. In any event, it's the rubber that has rotted/given out around the threads internal to it that are making your problem. Turning on the bolt head results in merely turning the whole rig around inside the rubber without ever acting on the threads.
If we're talking about the same thing and you're having the same problem, my solution was to grind off the old bolt heads and a judicious application of a prybar to free it all up to get it out of the way, and replace with new.
It's not anything you'll ever have to take apart again in your lifetime, but a sparing touch of an anti-seize compound on the threads in the replacement might be a good gesture toward the next guy.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
