Posted by IH fan on August 31, 2010 at 20:56:30 from (70.245.163.106):
In Reply to: farmall 560 posted by AL Farmall Boy on August 31, 2010 at 18:55:06:
Without knowing how the valve spool is configured, it's hard for me to know, but in most cases it should work. System pressure X area of the cylinder bore will determine how much it will lift. You're probably not going to lift much of a disc with a 2 1/2 or 3" cylinder, regardless if it's single or double action. You could use a double action cylinder with the valve configured for single, if the rod end of the cylinder is vented. In this case, it should be a filtered vent to keep dirt out or the cylinder will not last long.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
