auxillary hydraulic valves on 460
Posted by Paul Janke on September 01, 2010 at 07:06:52 from (216.166.168.54):
I am putting separate hydraulic valves on a 460 for the loader which is on the tractor. I am using a bank of valves with power beyond so I can go from the pump to the loader valves and from them to the tractor's original valves. The power beyond valves need to have a return to reservoir line. The only place I know of to put that oil back in the system is in with the return line for the power steering. Is there someplace better that I don't know about? Maybe a plug somewhere in the tractor's original valve pack? It has two valves for remotes and the fast hitch on it from the factory.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
