Posted by JoeVT on September 01, 2010 at 09:14:40 from (208.65.163.217):
In Reply to: Pump update for AndrewZ posted by Paul Shuler on September 01, 2010 at 04:41:47:
The rebuild kit is just gaskets and seals. It wont help the movement in the drive shaft. As Jim suggests, check the brass bearings for wear. My pump is currently apart, i can mike the bearing when i get home tonite and report back if needed. Also check that the drive shaft has the proper bearing. The bearing for the drive shaft is longer than the bearing for the pump gear. It's remotely possible that the pump could have been serviced in the past and the wrong bearing installed. But i would think if it had the wrong bearing it would have done a lot of damage to the gear teeth.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
