Re: Farmall H engine noise
Posted by GordoSD on September 01, 2010 at 14:38:40 from (216.106.245.74):
In Reply to: Farmall H engine noise posted by wfd2 on August 31, 2010 at 18:58:28:
When did you last adjust the valves? You might have a push rod problem. For sure drop the pan and get that metal out of the engine. I'd add a quart of diesel to the oil after you warm up the engine and let it idle for 5 minutes with that in there to get a really good flush. Then drop the pan and clean it. Change you filter again also.
Gordo
