First of all, Im not sure of your volt meters accuracy or the battery condition, BECAUSE a good batetry thats charged should read in the vicinity of 12.6 volts, unless theres a decent current draw which is dropping the voltage, of course.
Next, just where are you measuring that 13.2 volts on the Regulator, on its ARM/GEN terminal or the BAT terminal?????????? If the ARM/GEN terminal that may not be enough (depends on your meter accuracy and gennys output) to pull in and latch the VR's Cutout Relay in which the genny dont ever get coupled up to the battery (via closed cutout) to charge it and therey raise its voltage to the 13 and 14 volt levels. If that 13.2 is on the BAT terminal that should be enough to put at least some charge (pump current into) in the battery.
THE VOLTAGE THAT MATTERS IS ON THE BATTERY, it should read 12.6 setting but rise to the 13 and 14 levels if coupled to a good working genny. If the genny is actually only reading 13.2 volts open and unloaded (i.e. cutout relay is open unlatched) at fast RPM that dont sound quite high enough to me and the genny itslef may be bad or else theres a severe genny to VR mis match or the VR is bad or not well grounded
YOU NEED TO RUN PARA 5 OF MY TROUBLESHOOTING PROCEDURE which grounds the gennys FLD to see if non chargign is fault of genny or VR etc. be sure belt is good n tight also
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
