Posted by Owen Aaland on September 01, 2010 at 19:37:46 from (65.165.246.132):
In Reply to: 444, burned points posted by Spotted Horse on August 31, 2010 at 17:25:02:
You should need a resistor only if the wire between the key switch and the starter solenoid "I" terminal has been replaced. The original wire will look like it is made from steel rather than copper. There is a harness connector under the dash near the clutch pedal. If you unplug that connector you can measure the resistance of the wire between the solenoid end and the connector end. If the resistance is zero you need a resistor. If it is between about 1.4 to 1.8 ohms you should be fine.
If you need to add a resistor you can add it in the circuit either at the harness connector end under the dash or before it connects to the starter solenoid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
