If you get the tractor and cosmetic appearances are important to you, grind down the visible weld and CLEAN up the area, then slather a coat of epoxy over it and, as it's partially hardened, press a piece of sandpaper against the epoxy to create a surface texture similar to the cast iron block.
PRESTO... no more leaks AND a nearly invisible repair.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity!
... [Read Article]
