Re: Jacking up a Cub
Posted by Tom Fleming on September 02, 2010 at 02:59:26 from (206.193.253.243):
In Reply to: Jacking up a Cub posted by Dennis (VA) on September 01, 2010 at 17:21:56:
I use 4x4's and build cribbing. I just got done disassembling a parts A, and it was pretty simple. I jacked the front of the tractor up, built the cribbing under the torque tube and tranny, then let the tractor back down on it.
I then disassembled the tractor a piece at a time to keep the weight fairly balanced on the cribbing. If you build the cribbing right, it is the absolute safest way to work on one of these. BTW, the cribbing material should be wood planks, not cement blocks or similar.
This would also work for a Cub.
